Gearbox Mount
Car  Audi A6 Avant S-Line
Hi
Just wondering where I could get my gearbox mount and suspension bushes done, just after ringing a few garages and getting the same reply about the gearbox mount of "i've never done 1 before" or "if you go to a scrapyard and get one then i'll fit it" I give up on ringing them
Note on last service sheet
"REAR GEARBOX MOUNT WORN"
"PLAY O/S AND N/S FRONT TOP SUSPENSION BUSHES"
DazJ
dogbone mount. It's 2 bolts, what kind of garage are you going to???
top suspension bush (top mount), anyone that can fit springs (ANY garage) should know how to do this
dogbone takes about 5 mins to fix ( that including drinking your cup of tea too) and top mounts will be between 30 mins and 45 mins per side
rang partco and other companies, who all say that the gearbox mount is a dealership part, so I rang renault parts and they say they can't find it on the system, has anyone got a part number for this
EuroCarParts do the mounts, you'll either need the part numbers when you ring them because you get the same confused responses or you have go in and explain what you want
