Hi i know this has prob be said before i cant find it, I want to change my gearbox oil or just check it. I am no hands on man, how much do you think a garage will charge me for this, or over charge as the case may be ? I have never checked it and want too.
changing/checking gearbox oil is very very easy. under the airbox on the front of the gearbox is a plastic wingnut undo it(put a tray under the car to catch any if it comes out) the oil should be level with the hole, if not top up with a bit of hose and a funnel. to drain it remove the plastic cover under the car and on the underside of the box there is a plug with a square key hole in it undo and let the oil drain out job done.
rob5gt congratulations this is the first thread of yours i have read and you haven't been a **** (yet)
