Gearbox Oil Leak
I've got an oil leak from the gearbox on my 172. It looks like its coming from the rubber joint/seal where the gear selector goes into the gearbox. Is this likely to be an expensive thing to get replaced? Im guessing the rubber will only be a few quid, but couldn't figure out how much labour would be involved...... the little jobs often seem to cost the most to get done :(
Ive got the exact same problem with my 182 its not a major issue ive been told but am getting it done regardless coz its under warranty.
Not sure what they do exactly but I know it involves 2 rubber o rings and for the 1st 100 or so miles gear change will seem a little stiffer.
For peace of mind worth getting it checked out do you have a renault minut near you they could tell you how serious it is. I was told that mine wasnt that bad even though it looked bad (18kmiles) all the levels were ok, its when its dripping out of the nut/bolt next to the linkage thats when you should panic!
Rob.
