gearbox oil
If you remove the airbox, and look at the gearbox, at the front there is like a plastic wing nut. That's where you put new oil in.
There's a guide to the complete change in the guides section, sign up to be a member and you'll be able to view it.
Any idea on what oil to put in as my car has only done 57k. When i was changing the suspenison the oil was leaking out all over, I dont know whether to top it up or change it completley? If i change it completley how many litres will i need to use?
Did you pull the shaft out of the gearbox?
It's 3 litres of 75w 90 gear oil you need.
i think so me dads been working on it. so do you recomend me top it up or change the full lot quiet expensive gear :(
Change the whole lot.
You can get a gallon for about £20 inc vat.
