Stu.
lots of clios.
Right. was changing the rear pads so had in it gear jacked up the rear. when it was done dropped it down and went to pull out my drive, so nearly full left lock went to pull away and a big bang. still drove but was clunking (like a cv joint was fubard) stopped on the road checked there wasnt something stuck somewhere! drives in a line ok but when u turn a little bit you get an almighty crunching. and when jacked up the wheels dont spin free. drivers side usualy jams and the passenger has like a burring noise. Took off drivers side drive shaft and started it and went to try in gear and let it run but it was like the passenger side was snagging and wanting to pull it off the stands...just wanting to know if anyone has any idea what could be broken inside? or an explination. has been fine up till now! any help would be much appreciated!!
Stu
Stu
