Gearknob size??
Car  More poke than viagr
Hi, may sound a stupid question but im looking to get one of those pool ball gearknobs.
Only problem is that the guy requires the thread size and the depth of the hole for it to be drilled. :S
I have no idea of this and was just wandering if anyone on here did?
The knob is glued on, and the stick has a knurled top end, so no thread.
I will remove mines since i have a Allen screwed on Richbrook gearknob.
Let you know in the morning, nappy time for me! -ZZZZZzzz-
You know what... here goes.:
Gearstick is 12mm in size.
But since we have a lift-reverse... you can only go down 20mm (depth) with the knob, before the lift-reverse comes up 15mm with a 25mm surrounding.
(25mm for the plastic bit that holds the reverse lift-up)
So you have to square it off also underneath!
To warm to sleep anyhoos.
A pic. to explain the lift-up reverse room you need.
Wow thanks for going to all that effort for me :o
I just wandered if anyone knew the size, but didnt expect anyone to go and actually measure it, thanks again! :star:
i think this measurement need to post in cliosport guide
Extremely useful especially i am looking for aftermarket gearknob
:D
