getting speaker wire into door
hey guys I have just fitted tweeters into the interior mirror plates, and comps into the bottom of the doorcard. The car is a mk 1 phase 3 clio, so there were no speaker holes in the doorcard from the start so ive had to start from scratch.
BASICALLY GOT ALL MY WIRES OUT OF THE DOOR BUT NEED to find a way now of getting them from the grommit into the main chambre of the car. There seems to be a connection block in the way, and i cant remove it, do i need to crimp onto one of these connections, then on the other side take it back to my amp?, or are there better ways of getting the wire in?
You have to remove the connector !! It unscrews using torx bits ! Then put a hole in the grommit and feed through the cables ! Easy as ! This is how i did mine on the old RL !
M8, remember all that STUFF i told u ages ago, and on MSN!! That connector houses the central locking wires. wire it through that. And yes u need to remove with a torx bit first!
P.S. That is the only way the wires can be wired thorugh.
