Grinding noise from front...
Car  RB 182
At low speed and also when turning quite tight to the left/right...
Would this be brake related? Maybe something to do with a bush or bearing?
What is Reno's policy on broken or worn parts? I know they don't replace pads and discs...
dunno but i'm having a similar problem.. I'm gonna investigate tonight, probably in the dark which will be fun!
Its not the Strut Top.... You can feel the friction in the wheel when it slows down... The strut top is yet another thing that I need to get fixed. That happens when turning hard... The noise atm is slow speed and at any turning angle :(
Getting new pads and discs fitted too, so want to fix this problem first.
CV and Bearing... Are these covered or a "ware & Tare" part?
I have same noise, i had previous post about this and told it was jus a renault design fault, if anyone finds otu what it is leave it in here. My is when iim going full lock only.
I had a look lastnight, couldn't see anything obvious.. i've got a sneaky suspicion that it's the roller bearings on the nearside driveshaft but it's goin into reno for them to tell me..
If it is that i'll just do the work myself though. New gearbox oil while i'm at it.
I also noticed a small nick on the offside cv boot that looks like it could be leaking, are these easy to replace?
