Grounding point for sub wire; NEED QUICK REPLY PLEASE!
Car  1999 Clio 1.2 8V
Hi guys,
just about to go down and install my new Fusion AT1100 tube sub, just want to make sure I know everything I need to know before I get stuck in.
All I need to know is where the best point to ground the negative wire is!
Cheers!
Newbie
mines on seatbelt bolt under the back seat as me amps in boot also sand it to show bare metal :)
As close to the amp as possible. Use a bit of sand paper to remove any paint before bolting the wire down to ensure the earth is good.
Also make sure the fuse for the amp wire is as close to the battery as possible.
