i think they are diff diameters, i dont have the figures, but there is a torsion bar available off another clio (NOT 16v and im pretty sure not a williams eitehr) that is a decent amount thicker. But i have not been able to find out yet.
well heres the prob. The subframe is on. But its not straight. Unlike mondeos etc there are no locating pin holes or anything. Reference points to get it straight and along those lines.
Anything will be gratefully receieved oh ye of diminutive stature.
Oh, i thought you were using tehm to get rid of that ridge, lol......you just gettign carbon and crap off with them then?In most cases i dont re-use valves unless they are perfect, but if they are, chemically cleaned.
valve seat cutters are damn expensive and the hand powered ones are w**k as a wanky thing, and the diff angled cutters cost a fortune too.
Chemical cleaning is never all its cracked up to be. Even with blocks and heads, you still need to clean them by hand when they come back.
I only replace valves if they are knackered discoloured (the base metal) or the guides are worn. Unless its someone elses head and they want new valves to save a bit.
Even with new valves you need to clean them up, you need to polish em or you get the veiny thing on the back of the valves.
ill stick to the serdi powered cutter (i dont own it, no chance in hell! lol)
Cheamical clean and we have a soft shot blast cabinet to remove crud/corrosion and carbon without pitting and damaging the surfaces, heads not as important to be careful. But jeeze does the shot cost!
Its safe to say we are quite jewish with application and reuse lol.
I knew a guy with a serdi thing, but I aint got a grand or 2 lyign about. The bearings went on it and he contiue using it, So a pinto head was on it cracked the spindle broke and he died (hole about the size of a fist on his chest about the size of a bucket on his back, Simon has some crackign stories abotu industrial accidents).
The blast cabinets are good I gave mine to simon as I dont have a compressor to use it. And yeah the shot aint cheap.
Any of the normal (i.e. non-wide arch) Clio models that were specd with ABS had the four-bar torsion beam system fitted as they could take rear discs, which the ABS system came with. Must have been a very expensive option!
He owns and runs Capriotti Artisan, I was helping him the other week. We made tables, 14 altogether for a pub in glasgow. 2 grand they cost the pub. They will last and we made then from planks. No Ikea flat pack sh*t.
Its all big machines he runs and some are quite old and he knows their tricks. But if some muppet came in and tired they would end up losing a limb or gain a large hole somewhere.
