had one evening id rather forget
  2004 Clio 1.2 bucket
nope of my rear lights work on the drivers side so i thought ah fuses or just change the bulbs so i did both. also check the old bulbs on the passenger side and they work fine .
so im down to the earth wire although i cant find where it connects to i no it starts just behind the cluster but cant find where it connects to. i have also cleaned the rust off connecter pins using wd40 and a screw driver so this also isn't the problem
can any one help? (i have read all the threads on here and still cant work it out):dead:
  Storm Grey 200
You wont find where it grounds to, it probably runs off for miles down the loom. What i did to fix my issue which was similar to yours was to run the ground from the dodgy light to the working ground in the working lights, hey presto jobs a goodun.
  BMW 330ci Clubsport
The rear light's ground just behind the plastic cover closest to you when you open the boot. Its held on with 4 torx screws
