Done mine last year not too bad, about an evenings work once it's up on stands and the wheels are off. Worst bit I remember was routing the NS cable over the rear beam and once both cables are on it's just a matter of adjusting the tension on the adjuster which is best accessed by dropping one side of the heat shield on underside of car below the lever. Not rocket science tho.
