Clio 182
Hi guys,
I’ve tried searching the forum and can’t really find anything relating to my issue - apologies if I missed an obvious post!
I’ve done a few bits on the Clio over the past few weeks, one of which was the handbrake as one had snapped.
So I replaced both cables with genuine Renault cables as I had read that none genuine are incorrect lengths. I also had to replace my OSR calliper for a new part and also rear discs and pads.
My OSR handbrake doesn’t come on as early as my NSR, is there a way to adjust just the one side? I pumped the brakes and bled the system prior to adjusting the handbrake also.
Any help and suggestions is appreciated, I followed the same route of the cables too when they were fitted.
Thank you
Kieran
Thank you
Kieran
