Harness eye bolt?
The rears are but the side one isn't. You'll need to drill a hole for the inside lower one anyway.
But the outside lower one you just drill out and bolt it.
The rears are UNF and the b pillar is M10 from memory. No need to drill.
If you're fitting buckets could you not mount an eye to the subframe?
Does anyone know for definite what size the bolt is that holds the pretensioner to the seat, is it definitely M10?
What about the one on the other side of the seat (The outer side of the car) that holds the belt down the bottom? Same size?
