Harnesses- 182 with Recaros
  Recaro + Cupped 182
How would you fit Harnesses to a 182, or is there no easy way or is this just a rubbish idea?
  RenaultSport Clio Trophy
Nik has some in his Trophy, and so has SM. And many other members on here.
I'm comtemplating having some fitted in mine but I don't want any driling done as i wish to keep the car standard. Having spoken to Yozza about it it's completely possible and the harnesses can be attached on screws by the side of the recaros.
Nik's are attached at the base of the rear seat, with a quick release clamp (same as the seatbelt release) which you connect up when they're in use. So basically 2 parts.
Not ideal, but they're great if you want to keep your rear bench, and keep the practicality of the car! they also worked very well! :)
