Ello all, is there anyway of using harnesses on standard seats? i took my seatbelts out to respray my interior and theyve wound up n locked in place, unless theres a way to get them working normal that help too cheers!
i believe normal seat belts still have to be fitted and working, if originally fitted, for an MOT, even if harnesses are fitted. i know you can just have harnesses for kitcars. harnesses can be fitted to normal seats but tbh is it really worth it unless it sees a lot of track use; you won't be able to use the back seats properly and is 4 point harness any advantage over a seat belt ? ( 6 point is the way to go)
normal seat belts do not have to be fitted if you have harnesses for an MOT
mine passed fine with harnesses....never seen any posts on here of it failing because of it......and alot of people have them
