has ne1 had ne trouble with leaking......
Dont know about this model, since I havent looked inside the doors, but I had another car once that was leaking like that because the plastic sheeting over the inside of the door was removed. The water was free to run down the window glass and into the inside of the door, and it comes out a tiny hole in the front bottom corner of the door and onto the ground. But if you rip off or damage the plastic door lining (on the inside fo the door, just behind the door card) then the water can run inside the car.
Hope that made sense. Its kinda hard to describe :)
