Haynes manual for Clio anyone? Help needed!
Den
  Clio II/II 1.2 16V
Hi,
I hope you can help me. I'm looking for the inlet air temperature sensor?
I was told it's in the Haynes manual, but I don't have one on me :(
If anyone please could locate it for me, I'd appreciate a lot!
Thanks for your time!
  Renault Clio 1.5 DCI
From Haynes ...
Inlet air temperature sensor.
The air temperature sensor is located on the air inlet duct to the throttle housing on SOHC engines, and on the upper section of the inlet manifold on DOHC engines. To remove it, first disconnect the wiring from the sensor, then loosen the clips and remove the air inlet duct.
Unscrev and remove the inlet air temperature sensor from the air inlet duct.
  172 Ph1/Scooby MY00
Someone posted a photo recently showing where most of the main sensors were located. Sorry I can't remember the post, you'll need to try a search.
Cheers, Rob669
