The air temperature sensor is located on the air inlet duct to the throttle housing on SOHC engines, and on the upper section of the inlet manifold on DOHC engines. To remove it, first disconnect the wiring from the sensor, then loosen the clips and remove the air inlet duct.
Unscrev and remove the inlet air temperature sensor from the air inlet duct.
