Head lights
  Clio 182
Hi,
The top of my headlights are foggy/misty. I used a mop and got some of it off but still doesnt look good.
any1 else have/had this problem and what do you recommend?
cheers
McGherkin
McPension
Search Headlight Correction ;) (assuming it's in the plastic?)
If it's not in the plastic and is just water you can't get to, remove the headlight and blow a hairdryer in through the holes on a low setting.
  Clio 182
Yeah its the plastic, just searched for it. Somebody recommends a kit. Looks good once cleaned! Project for weekend keep me busy! Thanks for your help :)
If its the kit i think you mean (3M) then make sure you get some glass/clear sealant aswell. Ive been told the headlights will go manky again quite soon if they're not sealed correctly
  Civic Type R FN2
I watched a mate of mine use a 3M kit on his clio headlights the other day, they were quite bad but cleaned up really well. Didn't know that they often fog up again quick, I better go tell him!
Liamm
  Not anymore
I used the 3m kit but my drill stopped working halfway through the 500 grit so I had to carry on by hand, luckily I had 2000 grit to make the final part easier. They look a mess when the 500 and 800 grit are done but they do come up well once finished.
aye the 800 makes it oh so frosty ;)
  182cup & 172 racecar
500 is very rough. I started with 800 and that was bad enough, and you'll find it's really hard to get the deep scratches out.
