Headlamp washer jets not working
  Clio182
My headlamp washer jets aren’t working and I wanted to ask two questions:
1. Is there a separate pump for them, separate to the windscreen washer jets?
2. Where can I locate the fuse for them?
David172
  Clio 172 M135i
I wish I had a better memory because I had a problem with mine not working and failing an MOT 2 years ago. I THINK they have a separate pump to the windscreen washers so it could be that.
I believe it sprays the headlights separately so left then right and the valve/actuator had failed on mine so no spray to either side. It was a fault linked to the control module so they ended up wiring in a toggle switch so I could manually operate the left then right spray sequence. Bit of a faff, and they have since stopped working again so I'll removing it completely.
Hopefully it's just your pump. No clue about the fuse :p
Fairly sure this is the pump https://www.eurocarparts.com/search/488545100
