The right hand side beam is shooting high light high beam. How can I adjust them? I make sure that they don't have knob on the headlight nor there's a knob on the dash. Can resetting the ECU help or something? Pleaes help.
if you have xenons they are self adjusting, you can adjust them by a white nut thing ontop of the actuating unit, twist it and it will go higher or lower etc
first check if everything is in right position
hapened to me often when i was fidling around the light that i half opened the "bulb doors"
otherwise those whute knobs are for height adjustment
