Headlight blowing fuses and now the bulb please help me
Car  BG 182
Brought a 53 plate clio sport today with a lefthand headlight out.
I have replaced this bulb and it worked fine for around a minute it then started to flicker and then went out so i checked the fuses and it blew the 15a fuse so i have replaced this again for it to blow it again so replaced it with s 20a fuse which it didnt blow but then the headlight blew.
im guessing this could be either a faulty ballast or possibly an earthing problem or maybe a faulty bulb ?
The bulb has gone all white with a bit of black in it and has a tiny hole in it as if it was going to explode but hasnt
any help would be very appreciated
thanks chris
okay i thought the ballast was on the back of the bulb the black sqaure that the bulb fits in to. would i need to remove headlight to unscrew the lower ballast
Do not fit a larger fuse to a system if it keeps blowing. If it's blowing then there is a fault in the system that is causing the fuse to blow before damaging the rest of the system.
thats what i thought but i was told that if the bulb is flickering that its the fuse restricting the power flow to the bulb
Find out what the correct fuse is, then put that fuse in. If it blows then you know there is a fault somewhere in the system.
i did its a 15a fuse which is originally fitted which the headlight blew which is why i tried the 20a but this didnt work either
I have hopefully fixed this problem it ended up being the ballast was faulty and has half burnt out so ordered a new one and hopefully problem solved :)
