Headlight washer jet Clio 172 phase2.
Car  Renault Clio RS ph2
Hi,
My left headlight washer jet is broken: when I use the washer the "ball" shoots out...
I have tried to drive the ball into the jet but I have always the same problem when I use the washer...
Do I need new washer jet ? Can I repair the old one?
Thanks for help.
I have bought new one but I am curious if someone tried to glue the nozzle into the jet. So I haven't to take the bumper off.
Do you know if the ball is adjustable? The new one has the nozzle oriented in different way...
They are adjustable, but quite hard to adjust left and right.. up and down is easy enough though.
When its mounted on the bumper, a metal ruler stuck in the slit (ahem) should allow you to adjust it.
