Ok irritating problem
if my headlights are off then i can full beam no problem however if they are on then no full beam. i assume its a relay but haynes doesnt show where the headlight relay is. so can anyone help me out here?
its a Mk1 Ph1
I have the exact same problem mate, and my car just failed the mot because of it! im guessing that the indicator/headlight stalk will need replacing? but it would be nice if it were somthing as easy as changing a rely, can anyone else help us out?
Hi. I have a similar problem to both of yours. The only difference is that my full beam aren't working at all. I have found that the wire between the switch and the relay must have a break in it somewhere as I am getting no power between these. And if I use a power probe to power the relay the full beam lights, light up. Also I have heard that there can be a problem with the body control module on the clios. So I was thinking of just running a new wire between the switch and the relay but I have no wiring diagrams. Can any1 help me with this? Hope this has helped you.
