headunit cutting out!!
Car  RenaultSport clio 172 mk2
hi guys, right ive jsut fitted a new headunit and im getting the same problem as i did with my old one!
the problem is when the car is cold and i use the headunit it sometimes cuts out - happens even more when the temp is cold
it does the same thing then turning right sharp rights which i find very weird as all the wires are going down the passengers side??
what i mean but by out is just the music cutting out, the headunit is still on and the bass still comes through the sub its simply the music that stops
i have wired the headunit using block connectors (the ones with the screws on top), and they all seem to be secure
what could be the problem??
Check that one of the speaker connections (on the back of the speaker) isnt loose and that is isnt touching the other connector or the bodywork.
If the sub stays on and you have replaced teh HU its the only thing it could be
