Heal an toe’in
Who can do it? Used to have a valver when I was younger and found it impossibe but in the last few weeks ive started to have another go on the country roads back from work.
Can do it nice and smooth now but im that focused on gettin it right theres no way im doing it at any kind of speed for it to make a difference!
As for left food braking...................
Christopher
  Z4M
im still dipping my toe in the water when it comes to left foot braking!...lol
a few times iv needed to do it, so i did only for the ABS to intervene!....pfft! Give me a Cup anyday.
--chris
  Clio 200 Cup
Ive been trying to perfect it, not easy with size 13 feet but im getting much better at it. Doesnt make much difference on your average road but im hoping it will help me a lot come the nurburgring!
Left foot braking is immense fun to practise but unbelievably difficult to get right consistently
i dont drive without it anymore.
Downshifting is so unsmooth, jerky and wears a clutch like nothing else without at least a match.
  Street Triple R
i heel and toe every time i change down a gear, once you get the hang of it you will just do it without even thinking about it really
quick tip, which you probably will know anyway, although its called heel and toe, it is generally best to use the outside of your right foot to blip the accelerator, whilst using the inside of your right foot to brake, its generally a lot easier than trying to move your heel over to the accl pedal
its a good idea to practice this though because its very beneficial on your car if you use it properly, much less wear and tear on the clutch.
  E91 M Sport
I might try that jongsr4 :)....
Heal and toe used to be easy in my frp where the pedals were at the same level when applying the brakes and blipping the accelerator, but in the v6, even when the brake pedal is pressed quite hard, its still a lot higher than the accelerator pedal, so you can not physically get your heal that far down!
Any further tips would be greatly appreciated, cos not only does it cause less wear on the clutch...it sounds sweet too!
i find it easier to use the inside/outside of my foot rather than heel/toe. makes for a much smoother drive and as said above an easier life for the drive train of the car.
  Ziel Nurburgring
As per Jongs, i find it easier to use the one foot and balance it across both pedals, the 172s pedals are positioned perfectly ive found.
  E90
Yup same here, just roll the right foot over and blip the throttle, took some practising and foot slipping off pedals, but it comes naturally now.
  BMW e46 320 Ci Sport
tbh it sounds like a waste of time...although im sure im missing the point..
Ali
  V6, Trackhawk, GTS
No real need for it...I do it, but there generally is no need. Racing the caterham etc requires it in order not to lock the rear transmission.
  clio v6
when you are coming into a corner it stops the lurch on the box this causes a lot of strain on the gearbox, as the rear wheels are trying to stop turning.
as said by ajr.. a light rear wheel drive car will lock up the rear tyres and de-stabilise the car. on front wheel drive trailbraking is more effective... but thats another thread me thinks.... lol
*rubbish*, it depends entirely on how you drive, and i think the 172 being such a demanding engine to drive - IE you have to thrash it, it does warrant use.
It offers less mechanical stresses on the engine, and helps pass the stresses over different components.
/y0z
  silver valver/hybrid
hmm, thats worth noting , cus in the valver its impossible to get your heel up to the accellerator, havent tried it on the move yet though, probably get my foot stuck or something knowing me!
® Andy
  Illiad V6 255
Have heel and toed (well sidefooted) since I was a lad ... my first car needed double declutching on occasion too. I defo sidefoot when Im changing down at pace in the 172 ... easy to do ... tho dont over do it since K-Tec once warned me that <insert something technical to do with followers or somesuch> was the only weak point on 172 engine (otherwise bullet proof) and that doing too much of the "wow ... wow .... wow" engine braking / downchanges with blimps, might hurt. Who was I to argue ;)
What Ive been trying to get my head around recently is trail braking ... apparently will help with turn in on the V6. Probably not something for me to practicing in the wet in the 172 tho :confused:
  Mondeo STTDCI
I have dabbled recently though only blipping with outside of right foot. Easier when Im wearing my wider trainers!!
Would never ever bother with left foot braking. My left foot might as well be a lead weight as far as that is concerned.
i can do it just driving normally.
what i find hard though is doing it when you need it ie,
cadance breaking very hard and heal and toe at the same time.
now thats hard in the clio me thinks, so if you boys who say u can do that easy without thinking then your a better man than me :).
  Trophy #473
Ive mastered the double declutching, its second nature now, do it on every down change. But heal and toeing... i end up consentrating on getting it right with my feet and not on driving. i do find it hard in the clio tho, the brake pedal is quite high even when pressed compared to the accelerator.
must master it tho, its such a smooth and rewarding way of driving.:D
  FF 182, K5 GSX-R1000
Heel-toe on a road car is generally awkward, you have to realise that where this is used (on-track) the cars will have pedal boxes with well posistioned pedals to exactlly suit the driver.
Cant see the need on the road, gains f**k all on the drive home and the standard clutch is up to the job of even mild tuned fast road use.
almaghrbi
ClioSport Trader
  172 Cup
You cant claim you are a good driver without knowing how to do it. It keeps the car balanced while down shifting and it gives you a big advantage in the wet. You are meant to use the two sides of the foot not the heel or toe. The name belongs to long time ago (1950s) when the accelerator pedal was in the middle and the brake pedal was on the right...
How does this effect balance that much in a Clio (FWD) car? Weight is transfered over the front wheels anyway and will simply need adjustment to your braking pressure to prevent locking.
almaghrbi
ClioSport Trader
  172 Cup
Ok, I will explain
Once you hit the brakes, you have caused the car to slow down and you have already shifted weight to the front. As the car slows down the weight shifting has already taken place. Now you need to down shift to get the car in the right gear for acceleration through the next corner.... If you do not match the revs of the engine with the gear that you are selecting (achieved through heel and toe) you will jolt the car (another weight transfer) just before entering the corner. This 2nd weight transfer will unsettle the car and will result in lower grip through the corner. This is very noticeable in wet conditions
Why are you not selecting the correct gear during braking ready for use straight away to balance and then accelerate.
You honestly see this as a useful technique for the road?
almaghrbi
ClioSport Trader
  172 Cup
You are selecting the right gear while you are braking. But remember that at that point you will have your clutch on.
In racing, brakes are used to slow the car and gearing is what it is (to select the right gear, not to slow the car). This is because the ultimate balance control is achieved through the brakes not through gears. You will appreciate this when you brake really hard from top speeds.
Outside driving at the limit, this technique helps to save your gearbox and extend its life. and the more you do it the better sense you have of braking properly because it will help your timing.
Why are you not selecting the correct gear during braking ready for use straight away to balance and then accelerate. You honestly see this as a useful technique for the road?
if you were to do a lap (of a circuit and were then to do a h&T lap) in your car u think you would find the h&t lap a lot smoother)
/y0z
  dfdf
Gotta agree that it makes a big difference even if you only use it on downshifts. Ive got a Civic Type-R and its pretty common to drop down 2-3 gears at a time if you want to overtake. If you drop down from 6th to 3rd at 50 mph without blipping the revs up to 5k the jolt you get when releasing the clutch is seriously brutal. Been trying to do it when going round corners in conjunction with breaking (heel and toeing) but its not really something you can do without practice until it becomes second nature.
