Heat..
  20VT Clio & 9-5 HOT
My water temp was never above minimum unless I was in traffic. Anyway I had the thermostat changed Yday and its now just under half and stays there. Oil temp is also a bit higher.
Problem is my heater still aint that warm. Its ok if I put my hand over the blower. But anymore than about 5" and it feels cool. My RT was blowing v hot air.
Is this normal? or have I got something else wrong..?
Craig
  clio 20v
maybe its blocked like 16v clio said or there are leaves or summat blocking the heater
only other thing i can think of is on one of my old cars i had the dash out and broke one of the clips that held the temperature selector cable in place
this meant it worked fine on the cold setting but when i twisted the knob round to blow hot air it wasnt moving the cable properly and i only got semi warm air
adi
  20VT Clio & 9-5 HOT
hmmm cheers for the help. I think ill take a look at the weekend. Moderately warm is so much better than before. 25 miles to work shivering all the way!
Cheers, Craig
