Heater/aircon problem
Car  Clio 182 & C5 VTX+
Climate control is set to auto on 20 degrees but sometimes (especially if sun shining directly onto the car) instead of blowing out cold air I get super heated air blowing in. If I set it to minimum (cooling) I do get cold air but when I reset to 20 it starts to warm up again. Doesn't happen all the time, can go for weeks with no problems. Anybody got any ideas?
If you haven't used the air con over the winter, it may have developed a leak and needs the gas re-charging.
Your dealer can do this, but its better and cheaper to take it to an air con specialist, check yellow pages.
