heater blower not working at all!! help
Car  clio 1.2 sport
Hi all.
I have a 04 clio 1.2 with manual heater controls.
Does not work on any setting 1, 2, 3 or 4.
However the recirculation button lights up when pressed!
I first tried fuses. I dont know what one specificly controls this so I checked all of them! All were ok.
I then changed the resistor pack. No change.
I then changed the resistor pack again with a another fan (known working) no change.
I then changed the control panel. No change!
Could someone please tell me the specific fuse number so I can check power getting to the fuse. Also the colour of wires in back of control panel that should be getting power (I belive the white plug)
Other than a possible break in wires does anyone have any advise/ experiance of this problem?
Also car doesnt have a/c.
Cheers lee
I have changed twice now. Also doesn't work when bridge wires on resistor as in other posts! Definatly something else wrong!
Cheers anyway mate
I had to change my resistor..... was about to say check fuses but you have stated that you did? Have it into a garage mate....
Probably the fan motor then.. If you bridge the pins 1 and 5 and still doesn't work.. Can only be a fuse, motor or earth
