Heater problem
  clio sport 172
Hi All
my fan does not work at all in the 2002 clio 172 the display works in the car and all the flaps seem to move when i press the buttons so i can see the fan speed going up on the display but nothing at the motor end - i have taken the motor out and put direct power to the motor and it works perfectly so can i assume the resistor pack has failed as i cant see any fuses that have blown or i just cant find the relay etc
if somebody can point me in the right direction as to where the fuse and relay is ( if it has one ) and i will check that and which is the supply wire to the resistor to make sure it is getting power
Many Thanks
  clio sport 172
heater all sorted brand new resitor installed and all working again happy days just need to sort the speedo out now
