Fiesta ST-2 Finsport
m88rk u think you have had bad luck!!:-
Bought my second valver last week and blew the gearbox up within a couple of miles of collecting it!! oh f**k!
Found out it was a 1200cc box in it whilst i was changing it!!!
major bad luck. Anyway all back in with a lovely proper recon reno jobby-(found out the hard way of changing the box-taking the subframe out and leaving the engine in the friggin car- bad idea- took 2 and a half days solid!!!)
all ok and running fine, but within a day it started to missfire, running like a pig and knocking when revved (a bit-pinking?).
Its hesitating and all sorts!!! its now undrivable and i am screwing!
I need some help! i have changed so many bits- ht leads, plugs, coolant temp sensor, potentiometer, idle speed control valve, ignition module, checked all the leads, connectors and earth straps and i am exhausting all the possibilities i can do @ home!! I swapped ecu- but other wouldnt work-security immob?
Anyway the car is chipped, cams, p&p head ect ect if that helps!
I really need some ideas but it looks like its gonna have to go to bb tuning. ( but f**k knows how i am going to get it there!!)
a spark is comin 2moro to exctract the fault codes for me but i cant see anything being logged!?!?!?
Any ideas!!! ??????
i am majorly pisssed!!
Chris
