Help - 182 problems!
  Clio 182
Need help with my 182 which I've owned for 6 years now. It's done 74k miles (2005 plate) most of them I've done myself. I gets a good run on A roads every day and gets driven around 20+ miles a day.
It's been back and forth to the garage in the past month to sort out ongoing problems all related to the engine management diagnostic problems. It started with what I thought was a misfire and not running on all cylinders, also engine management light on, and running rich. This is the work carried out so far:
- downstream O2 (lamda) sensor
- upstream O2 sensor
- coil pack
However, just when I thought the problem had been fixed the light has reappeared and is now flashing intermittently....I'm taking it back to the garage and they'll run diagnostics again, but I wondered if anyone here recognised the problems??
Really would appreciate your help and any support!
Many thanks
Chris
