Clio 197 RS
Hi everyone,
I’m desperately in need of help.
Normally I’m able to fix pretty much everything, but this time I’m lost.
So I’ve got a Clio 182 (2004)
I’ve got a couple of issues...
I bought the car with a bad misfire, and turned out to be a trapped plug lead which was arcing. I replaced the leads and plugs and it ran very well.
After driving it, discovered another fault!
Once warm/hot, and car turned off, it would restart straight away. But if left for longer than 10-15mins, it struggled to restart again. It would crank over and over very quickly and slowly splutter back to life.
But it revs freely and feels responsive etc as it should... which brings me onto the next issue, over 6k it splutters, bogs, pops, misfires and bangs (as if it had antilag and launch control) when it does this I’ve noticed the eml flicker once or twice.
So far I’ve changed
•HT Leads
•Plugs
•CPS
•CTS
•Injectors
After a few days of getting it running again it wouldn’t start at all and threw up codes for CPS, so I replaced it with a new one which didn’t work, but after swapping wires around in plug it worked...
It’s really becoming a headache 😞
Any help would be greatly appreciated
So far I’ve changed
•HT Leads
•Plugs
•CPS
•CTS
•Injectors
