Ferris! Car Clio 172 ph2 Mar 22, 2014 #1 hiya needing to fit camber shims asap. tryed to undo the bolts behibd hub but they just keep spinning is the caliper and disc needed to be removed?
Mini182 Mar 22, 2014 #2 Rear camber shims are fitted behind the stub axle. Disc needs to be removed in order to access the torx head bolts.
Matt e ClioSport Club Member Car Megane R26 Mar 22, 2014 #3 they fit like the hub spacers http://www.cliosport.net/forum/showthread.php?674113-Hub-spacers&p=9199984&viewfull=1#post9199984
