Help - Can not get the Back Doors Open
AS Title Says Have a V Reg Clio. 1.4 RT. About 6 months ago the back passenger door would not open. Got permantly locked when someone tryed to open the back door at the same time as I pressed the Button next to the gear stick to open all doors. Then same thing again happenes on other back door Today. I have took the door card off one door. Tried everything from yanking the rods that connect to the door pin and connect to the Door lever and no success.
I was talking to someone today and the Said You can reset the Child locks by Hold that button down next to the Gearstick for 10 second as you turn the ignistion and there should be some bleeps, but again no luck..
I am fed up!!!!!!!!!
Thanks Darren
