Got a 1999 V Reg 1.4 Clio for the other half 6 months ago. In that period there has been problems changing gears. Got that improved as I got a Mechanic who said the Gear Linkages are prone to ceasing, so he sprayed loads of lubricant on it which improved it. In the last 3 months its been stalling at junctions , traffic lights etc when the engine is cold. Then last Week it Broke Down. Would hardly tick over, kept revving, and also backfiring . Got it to a Tuning place who fixed it saying the MAP Sensor need replacing. Got it back yesterday, and although its fixed the COMPLETELY KNACKERED AND WILL NOT RUN' issue its back to its previous state of cutting out at junctions. Its A little worse than a couple a months ago and Sounds a little Rougher, but that may be down to the exhaust slightly leeking now due to all the pressure off the backfiring on its latest major fault. The Back Brakes now stick on, if leaving it for a couple of days, which ive been told will need to be stripped down to be repaired. I know from these forums that trying to cure the Stalling could cost a fortune trying every method to cure it.
I know I cannot really sell it privately now. I was gonna put a 12 months MOT On it and put it in a Car Auction that is near us. What do yous think???
