hi guys got a sligh problem my climate control has packed up the display and everything works fine but no matter what speed it is not getting and air out of the vents and their is no noise at all help help what has happened????
btt been told it could be a resistor but renault say if it was resistor it would work on full power only but it is not doing this..the resitor is 129 from renault what else could it be cheers
hi there mate i can here the a/c pump click in and all the flap noise you can normally here in the car is all fine!!! its just there is no fan noise!!!!!
99,9% the problem is here
7701051272 - regulation of heat (this is lousy translation from Croatian )
Me and few my friends had the same problem on our cars, and the problem was in that part.
The price for it in Croatia is around 70€.
It should be the same for LHD and RHD cars
It is the part under number 6 on the picture
