Help help shaking steering wheel violently
  alien green rs133
not a buckled wheel??? wheel would still be balanced but have a dent it and it will affect it at speed
  Megane 230 R26
I can't believe something manifesting itself in such a severe manner hasn't been found when someone with at least half a clue has examined the car...
Also if it's that violent and you can barely hold onto it I'd stop deliberately triggering it before you actually crash? LOL...
  Megane 230 R26
Hope you get it sorted, sounds nasty! If it's not wheel balance, bearings etc. then it must be suspension, steering or drive related...
  Dodgy one
Are any of the brakes binding on the N/S? Could have got hot, warped a disk causing the vibration and pulling left.
Its that or CV completely gone IMO.
  M135i, 118 coupe
Rear discs are pretty nackered so they need changing
Rear Shocks have gone
Driveshafts need checking so one of those 3 or a combination of them all probably
  172 Ph1
weird that its only done it on the motorway and 3 times, but its clearly speed related.
Hopefully it will be something obvious and i wont have to take it to a renault spechialist
One thing no one has mentioned is the road surface, if its only motorway when it happens, is it the same road or a diff road? and is it the same place everytime or a diff place? this needs to be eliminated.
Falling into lorry ruts makes the steering pull left and right like mad and bumpy tracks taken at speed will produce rumbles and vibrations
Hope this helps
lemonnobby
i bought a complete driveshaft from renault dealer in bristol(s j cook) it cost me £144 inc vat with £11.50 surchage( so about £132.50) orderes on a monday came on thursday. i fitted it myself so wasnt to bad(but mine is a ph1)
Are you local then as i work for them
  2003 clio 172
i had this exact same problem turned out to be the offside cv its well worth gettin it looked at i got a new driveshaft for mine for 117.50 so wasnt to bad
Dan
