Help installing Parrot CK3000 bluetooth handsfree
Chris, I just looked at Parrot kit I have here and on the Clio set wiring.
All you have to do is connect the long yellow wire to the blue wire that has the label "MUTE IN 3"
That should do it....
BrianR do the clio models have a different radio on them with different wiring position for the telemute?Mine is plugged into telemute 1 and does the job
Sorry to be a simpleton but you mean the yellow lead from the parrot, to the blue mute in lead from the parrot?
Cheers (again).
I think they do, I had a look at the plug pin outs for the CD tuner and it shows pin 3 as the mute. (blue on Parrot)
Telemute 1 (White on Parrot) is pin 1 on the Iso plug and shown as the vehicle speed input on the CD tuner.
Telemute 2 (yellow on Parrot) is pin 2 on the Iso plug and shown as "not used" on the CD tuner.
It may vary on other head units though. I might look later.
