help me please
right, the symbol in blue somtimes comes on and runs like a bag of s**t but this is due to the ecu cver rubbing on the wires and is now showing the bare metal, i can fix that no probs,
but sometimes the symbol in red comes on and i have to really rev the car for about 45secs for it to go out? why? what is this? starter motor? if i dont rev it the revs are all over the place and it sometimes just cuts out.
  Renault Clio, 216 Tomcat
be an electrical prob.. is there any particular time it does it for example mine does it both cars when its rain some times due to having to move stuff around for tuning parts and such..a dn my revs will dropp then go to nearly red line and cut out.. if the wires are down to bare then it could also be them shorting on each other .which case will be a seriouse **** up in the end.
i put some tape around each one but now i cant get the ecu cover off to re do it, cvut my finger to fecking peices lo,,
  Clio 182
If the wiring loom has rubbed through u will av to replace it (as u can never repair it correctly). and if the fault continues it will most likly to be the throttle body as this is a common fault in 1.2 clios. But most ov the time if the loom has rubbed through the throttle body will be ok.
hope this makes sence as im tired lol
