Help my clio
Car  Renault Clio 1.4
Hi I have 1.4 Renault Clio. It flashed up check injectors lost power. I pulled over as I was on motorway at time.. Car will not start. AA man said looks like cambelt..?????????
Could be cambelt, that would stop everything
Ok. Thanks is this an expensive job... First garage it was towed to after I broke down on MOTORWAY lol said it would be £600. Waiting to bring to Another garage ( my own ) for them to check it out...
If the cambelt has slipped then yes, it's extremely expensive. It's a £400 job alone just to get it changed at the interval. If it's slipped or broken then chances are the valves have smashed themselves. Pistons are f**ked and so on. Leaves you with the options of getting the top engine rebuilt or a donor engine dropped in.
easy way to check is take the oil filler cap off and swing it, if the cams turn then the belt has not broken...
