Help needed changeing air bag ecu , seat and pre tensioner
Car  A3 2.0TFSI QUATTRO
My seat airbag and pre tensioner has gone off so i have got a new seat , pre tensioner and air bag ecu/module
Am i safe just replaceing them all ?
Do i need any sort of computer to get the air bag and service light off
Any help will be a god send
I think if you have replaced the pre tensioner and the airbag, then after replace a new or second hand air bag module with no fault codes on the light should go off and airbags should work fine again. Or you can fit the airbags and pre tensioners and get the fault codes removed of your current airbag module, then after replacing i think the light should go off :)
Ahhh just what i was looking for i thought that but wasnt sure
New seat with un deployed air bag , new pre tensioner so in theory new module with no "codes" or previous air bag deployment i should be fine
Thanks alot
Yes i think that's correct. I hit a curb and the seat air bag, passenger pre tensioner and rear seat pre tensioner went off... I replaced them all, sewed the seat up, but haven't got around to buying a new airbag module yet.
i hit a pothole and passanger seat airbag and pre tensioner went off so got all bits for cliospares (as was) but not got round to swapping them over
thanks for the info
Am going to do this today
Is it as straight foward as unplugging ecu and plugging in the one ive got or do i need to dis connect the battery 1st
Also how do i get to it ? Do i just pull ash tray out or do i need to remove more
