Help needed for PH1 handbrake cables
Car  2xPh1, Corsa rally
Changing the handbrake cables on my early PH1 and purchased from Renault parts given
R60 00 073 733
R60 00 073 734
When fitted the cables are about 60mm to long at each side,the outer sheaths fit spot on. Had to cut old cables off so hard to compare against each other.
Are these the correct cables or have i been given PH2s.
I believe early phase 1 have a different adjustment arrangement to later phase 1 and phase 2 so possibly different cables, you may know this already, so yeah I would guess you have the wrong cables although I cannot help with part no,s.
Yeh my cable is adjusted from inside the car under the handbrake cover.
Been on to Renault and they want me to take the cables in as maybe a issue with cable lenghts.
would be nice to know difference between PH1 and 2s
early phase 1 adjusts in the car, late phase 1 and phase 2 adjust under the car.
Give me a steer or photo where to adjust under the car?
Have it on ramps atm, but not to much room to whizz about and explore
no pics but you should be able to see the adjuster from underneath, if you can't then will be on the handbrake itself.
