Help needed on gearbox oil refill.
Car  225 powered mk2
Basically how does it come off? only had a quick look, but its really hard to get hands in etc, but it seems very tight. Question is how does the filler plug come out? and what sort of tool is needed??
Any tips on how to refill it with oil aswel please, as it seems to hard to get a bottle in there?
many thanks.
You can fill it up through the breather but the filler hole must be open so you know when to stop..
that takes ages... Fill in the front hole of the box instead. Cut a piece of garden hose and it fits perfect in the hole. Attach a funnel to the other end, fill the box with 3liters of new oil. No need to remove anything but the engine underplate. Remove the hose and let the overflow pour out. Mount the plastic cap back and your done.
Oil is supposed to be Elf Tranself NFJ 75W80 only.
Where can I buy Elf Tranself NFJ 75W80 ?
I did buy some from a Renault main dealer once but it was hugely expensive!
