help needed please
i have got a mark 1 1.4 rt which i ahve lowered 35mm at the front using lowering springs, and by 40 mm at the back. i am gona put on 16 inch alloys with 195/45 tyres, will they just fit straight onto my hub or will i need to do nething b4 i can put them on? spacers????? will they fit with the existing shocks????/
As long as your shocks are in good condition and the alloys are the correct offset then it should fit no problems. Ask your alloy wheel supplier what offset you will be getting. If im not mistaken the offset of et 35 is correct for clios.
Chun.
