Help needed with hubs please
  • Thread starter Thread starter 16vturbolee
  • Start date Start date
1
16vturbolee
225 CUP Hubs, Would they fit the valver, cos i got the brembo's and discs of 1, had bigger wheel spacers and bolts and fixin kit all done by bbpt.Just pullin into the garage to fill up then pop, ALL 4 wheel bolts sheerd off and drop the disc on to the wheel scrachin the brake cal. slight kink in the wheel arch to.:mad:
Im not sure what to do now:S
All the wheels were torqed to 120 nm and the AA bloke taped the rest of the bolts out with a punch so they werent over tight:S
So not drivin the car at the mo so any help would be great thanks
were you running studs? 225 hub will never fit
its 100nm for wheel bolts (well 90 actually, but i use 100)
I dont know all i got on the invoice bill is wheel spacer kit/longer bolts £59.00
Brake spacer design and manufacture to suit supplied discs and calipers, includes bolts and disc machining and labour £315.00
