Getting the head skimmed on Monday and the bloke doing it said the I don't need to remove the valves but I had a look at them and they are petruding so I don't see how it can get skimmed like that? Any easy way around that?
Valves look below flush mate? It depends how he mills it. If he fly cuts it all at once you will need to remove protruding valves, if he is using a milling head he can steer around the valves.
Its better to have it fly cut as there is no chance of varying thickness /lips.
I will remove that anyway but in the second pic you can see the valve that's second in from the right is sticking out slightly more than the others for some reason?
