help!!! no power steering
lawrence
  is non-existent
the bloody pipe under the airbox is leaking fluid had been tricklikng for a few days now, but this morning it finally spewed its guts, is it an easy fix, for now ive just chemical welded it but how easy is it to replace the pipe?
  Mint Clio Valver!
i been quoted £141 to fix mine. Doesn't sound like a price to match an easy job. what car is it? mine's on a valver.
  Lionel Richie
if its the line that goes from the pump to the rack then its a b*****d to change plus it costs £170 from renault!!
you have to remove it through the passenger side wheel arch IIRC
lawrence
  is non-existent
jesus how much!!! ill get a pic of the line tomorrow, but its the line that runs width ways of the car under the clutch cable
lawrence
  is non-existent
well i would do but like i said in the pm, but i still want to do it myself
  Lionel Richie
maybe, but i remember doing yoz's with the car 6feet in the air!
i think i pulled it out either the passenger side wheel arch, or from under the subframe
lawrence
  is non-existent
any idea how much the replacement pipe is? i had a look at work earlier and it looks quite tight but do-able
