Here we go bought this car as a non runner 2002 172 changed ecu uch and key so that rules out ecu flywheel sensor & connector changed checked for broken wires from ecu to flywheel sensor & coil pack also tried different coil pack. removed an old cobra alarm to rule that out, It is priming the fuel pump immob light on dash fine just can't get a spark also swapped a few releys around the only one I hav'nt changed is the yellow one in engine bay.
I'm not good with wiring diagrams any help welcome.
Based in Newcastle upon Tyne.
